It is currently Mon Aug 11, 2025 2:57 pm
 Post subject: Quick and Basic Finish
PostPosted: Sun Jun 12, 2016 3:51 pm
Last Name: Ensor
City: Springfield
State: Missouri
I am wanting to explore the idea of a simple, quick finish that I can use as an alternative to the full gloss I currently offer. It could be sprayed or applied by hand... maybe even open pore. I am thinking satin or semi-gloss. The idea is to be able to offer a cheaper alternative that protects the guitar but isn't as flashy as a full gloss. I am looking for something with more protection than an oil finish, but less work/time than a full gloss finish. Any suggestions/experience?
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sun Jun 12, 2016 6:13 pm
If you have a decent spray gun most satin lacquers will give an acceptable "off the gun" finish. You can do fewer coats as you are not removing any finish.
PostPosted: Sun Jun 12, 2016 7:18 pm
I really like Minwax Wipe on Polyurethane. It takes 2 days to do 6 or 7 coats light sanding with 400 grit between every couple of coats. The other Satin that I've had good luck with is Enduro-var. You can do three coats in one day and your done. It takes a bit to learn the spray settings, no worse than any other new product, pay close attention to the temperature and humidity recommendations. As Clay stated, lacquer will work very well also. Three coats is all you need. On your last coat replace 1/2 of your thinner with acetone and your finish will lay down very nicely. All three will give ample protection to your instruments.
PostPosted: Sun Jun 12, 2016 8:27 pm
I've had very good results with Watco Satin in rattle cans -- last coat self leveling, no buffing or polishing. Here's a Black Walnut tenor uke no pore filler.
Ken Cierp
PostPosted: Mon Jun 13, 2016 3:07 am
Enduro Var.
This one's the flat, straight from the gun, no pore fill, but Z-epoxy on the neck only.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=47792
PostPosted: Mon Jun 13, 2016 8:10 am
Flat --- nice, I'm going to give that a try.
Ken Cierp
PostPosted: Mon Jun 13, 2016 8:57 am
First name: Brad
Last Name: Combs
I've had trouble finding the flat from the usual suspects (woodcraft, rockler, etc...). I called a few of the distributors on the GF website but no-one had it. I found it on Amazon. I'm wondering where you are getting it?
PostPosted: Fri Jun 24, 2016 6:35 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Tru-oil?
PostPosted: Fri Jun 24, 2016 7:46 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
kyllä = yes
hyvää huomenta = good morning
ei = no
kiitos = thanks
Was there an instrument building question here?
- Beth Brower
These users thanked the author Woodie G for the post: Pmaj7 (Sun Sep 04, 2016 1:29 pm)
PostPosted: Fri Jun 24, 2016 8:40 am
Nils wrote:
Tru-oil?
Perhaps you fired off a reply before you read all the post? -
PostPosted: Fri Jun 24, 2016 11:50 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
+1 for wipe on poly.
PostPosted: Fri Jun 24, 2016 12:03 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Woodie G wrote:
kyllä = yes
ei = no
kiitos = thanks
Näen mitä teit siellä. . .
Bryan Bear PMoMC
PostPosted: Fri Jun 24, 2016 3:24 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Bryan Bear wrote:
Woodie G wrote:
kyllä = yes
ei = no
kiitos = thanks
Sinun ei pitäisi rohkaista minun käyttäytyminen !
- Beth Brower
These users thanked the author Woodie G for the post: Bryan Bear (Fri Jun 24, 2016 3:41 pm)
PostPosted: Sat Jun 25, 2016 8:29 am
"I've had trouble finding the flat from the usual suspects (woodcraft, rockler, etc...). I called a few of the distributors on the GF website but no-one had it. I found it on Amazon. I'm wondering where you are getting it?"
You can also add "flatting" agents (usually silica) to regular lacquer to make it "flat". The silica particles scatter and disperse the light that hits the finish.
Users browsing this forum: J De Rocher and 52 guests
